[vcf-midatlantic] weather, was Re: Workshop 8/20 & 8/21 location change
David Hoelzer dhoelzer at enclaveforensics.com
Sun Aug 14 20:02:21 EDT 2016
(Submerged as in subterranean, not as in under-water. ;)
-----Original Message-----
From: vcf-midatlantic [mailto:vcf-midatlantic-bounces at lists.vintagecomputerfederation.org] On Behalf Of David Hoelzer via vcf-midatlantic
Sent: Sunday, August 14, 2016 8:00 PM
To: vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org>
Cc: David Hoelzer <dhoelzer at enclaveforensics.com>
Subject: Re: [vcf-midatlantic] weather, was Re: Workshop 8/20 & 8/21 location change
Obviously not... living on an island and having a fully submerged basement doesn't hurt though. It's only about 78 down there even though it was around 90 outside today.
From: vcf-midatlantic [mailto:vcf-midatlantic-bounces at lists.vintagecomputerfederation.org] On Behalf Of Dave McGuire via vcf-midatlantic
Sent: Sunday, August 14, 2016 7:51 PM
Cc: Dave McGuire <mcguire at neurotica.com>
  So if it's 110degF it's ok, as long as the humidity is low? ;)
           -Dave
On 08/14/2016 07:43 PM, David Hoelzer via vcf-midatlantic wrote:
> We have a permanently installed dehumidifier downstairs where the rack
> is. Honestly, at 30-40% humidity, everything down there is peachy
> keen. :)
> On Behalf Of David Riley via vcf-midatlantic
> Sent: Sunday, August 14, 2016 7:29 PM
> To: mloewen at cpumagic.scol.pa.us; vcf-midatlantic
> Cc: David Riley <fraveydank at gmail.com>
> location change
> On Aug 14, 2016, at 16:29, Mike Loewen via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>>> On Sun, 14 Aug 2016, Dave McGuire via vcf-midatlantic wrote:
>>> Same here in Pittsburgh, awful heat, similar temperatures, humidity,
>>> and patterns as Florida.  Air conditioners are not even coming close
>>> to keeping up.  At night the temperature is only dropping by a few degrees.
>>   Turn off the VAXen.
> Er, yeah. I was searching for tips on insulating our basement, and it turns out none of the DIY sites have any advice on how to keep server/mini heat out of the REST of the house. Alas.
> - Dave
Dave McGuire, AK4HZ
New Kensington, PA
