[vcf-midatlantic] What should be on our (tiny) workbench?
David Gesswein
djg at pdp8online.com
Sun Feb 7 10:47:16 EST 2016
On Sun, Feb 07, 2016 at 12:04:27AM -0500, Evan Koblentz via vcf-midatlantic wrote:
> As previously mentioned, our new museum space will have a small
> bench area. This won't be a fully equipped workshop, due to space
> (and also because we can use the IXR hackerspace's workshop whenever
> needed), but it will be good for quick/simple projects.
> What equipment should be put in there?
DVM.
I use these frequently
Various clip leads, heat shrink and heat gun, wire selection.
Does the desoldering station have a good tip and do you have spares? Mine
has tips with different size holes for size of lead desoldering.
> What else should be seek, especially re: anything of significant cost?
For a small station rest is probably just nice to have. Other tools I use
Lab power supply, logic analyzer, ESR meter, transistor tester.
For hand tools good cutters, strippers, needle-nose pliers, and standard
tools for disassembly.
