[vcf-midatlantic] Received H11-a shipping mess!
Systems Glitch systems.glitch at gmail.com
Wed Feb 10 20:59:55 EST 2016
> It’s a two-switch front panel with a 3rd toggle switch connected to two posts on the power supply board
If it's like a LSI system, it's probably for the Line Time Clock (LTC).
> The CPU has 5 40-pin chips (two purple ceramic and three PDIP). Supposedly the H11 has a monitor PROM or something like it, but I don’t see anything like a PROM on the board. Guess I have to wait until I get it running!
Sounds like the LSI-11 chipset (based on the WD16 multi-package CPU). If so, it's got ODT microcoded right into the processor. You'll still need some working RAM and a SLU at the typical address for it, though. Do you know if it's just a rebranded DEC board?
> Is there anything else I should know about the H11 while bringing it up?
>From what I know about the H11, I believe some of their cards are just DEC boards (CPU, possibly some of the RAM options). Can you post pictures of your boards for us to identify?
Thanks,
Jonathan
