[vcf-midatlantic] Received H11 - it works!
Richard Cini rich.cini at verizon.net
Fri Feb 12 23:12:08 EST 2016
Dave —
	The RUN light thing now makes sense. Thanks for clarifying it. I’m still reading the 11/03 manual.
	The SLU is from Heathkit and it’s a single port SLU probably equivalent to the DLV11/M7940. The primary card is set for 176500 and a vector of 300. I have a second card that I wanted to use to connect to a TU58 emulator but maybe there’s a better way to accomplish this.
Rich
Rich Cini
Collector of Classic Computers
Build Master and lead engineer, Altair32 Emulator
http://www.classiccmp.org/cini
http://www.classiccmp.org/altair32
On 2/12/16, 10:34 PM, "vcf-midatlantic on behalf of Dave McGuire via vcf-midatlantic" <vcf-midatlantic-bounces at lists.vintagecomputerfederation.org on behalf of vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>  Congrats!  I'm typing this on my phone so I'll be brief.  The standard
>CSR address for a TU58 is 176500.  What second SLU do you have?
>  Also, about  the "run"  light... Keep in mind that ODT, the prompt you're
>interacting with, is actually written in microcode...not PDP-11 machine
>language.  When you're at the ODT prompt, the "PDP-11" part isn't actually
>in the run state,so it shouldn't be on until you actually begin execution
>of some code you've loaded into memory.
>                  -Dave
>Dave McGuire, AK4HZ
>New Kensington, PA
>On February 12, 2016 9:46:16 PM Richard Cini via vcf-midatlantic
><vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>> All —
>> Made some good progress today. I built the console cable and verified that
>> the serial console board was properly jumpered. I put in all of the boards
>> and turned it on and I saw the following on the console:
>> 173002
>> Yea! Looks like it works. I connected it to PDP11GUI and ran a memory test
>> and it seems to be fine. Interestingly, the RUN light only blinks at
>> startup and no other time. Not sure what that means, but it’s running.
>> I have a couple of things to do:
>> *  I need to repair the side panels. I bought epoxy putty today and I’ll
>> give that a try tomorrow.
>> *  I’d like to remove the flat black paint from the metal front panel. Any
>> recommendations? It looks like regular latex paint on top of the painted
>> metal panel. I have a 3M “safe” (non-VOC) paint stripper that I was going
>> to try.
>> *  I have another SLU that I’d like to configure for use with the TU58
>> emulator. Any advice on this?
>> Thanks! Very exciting day indeed.
>> Rich
>> Rich Cini
