[vcf-midatlantic] Received H11 - it works!
Dave McGuire mcguire at neurotica.com
Mon Feb 15 01:45:01 EST 2016
On 02/12/2016 11:12 PM, Richard Cini via vcf-midatlantic wrote:
> The SLU is from Heathkit and it’s a single port SLU probably
> equivalent to the DLV11/M7940. The primary card is set for 176500 and
> a vector of 300. I have a second card that I wanted to use to connect
> to a TU58 emulator but maybe there’s a better way to accomplish this.
  Are you certain?  The console needs to be at 177560; everything
depends on this.  176500 is the correct CSR address for the SLU used to
interface to a TU58.
             -Dave
Dave McGuire, AK4HZ
New Kensington, PA
