[vcf-midatlantic] Received H11 - it works!
Richard Cini
rich.cini at verizon.net
Mon Feb 15 08:22:07 EST 2016
Dave -- the settings on my card are actually correct and the console works; it was my reading of the jumpers on the board which was bad. I also grabbed a copy of the DLV11 manual and saw how it split the ports for use with the TU58 and the console.
I configured the second card to be at 176500/300 and 9600,8N1 so when I have a chance to make up a second serial cable (parts in order from Mouser) I'll test it.
Thanks!
Sent from my iPhone
> On Feb 15, 2016, at 1:45 AM, Dave McGuire via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>> On 02/12/2016 11:12 PM, Richard Cini via vcf-midatlantic wrote:
>> The SLU is from Heathkit and it’s a single port SLU probably
>> equivalent to the DLV11/M7940. The primary card is set for 176500 and
>> a vector of 300. I have a second card that I wanted to use to connect
>> to a TU58 emulator but maybe there’s a better way to accomplish this.
> Are you certain? The console needs to be at 177560; everything
> depends on this. 176500 is the correct CSR address for the SLU used to
> interface to a TU58.
> -Dave
> Dave McGuire, AK4HZ
> New Kensington, PA
