[vcf-midatlantic] OT: dual booting W7/Linux
Dean Notarnicola
dnotarnicola at gmail.com
Mon Feb 29 22:24:35 EST 2016
If you don't want to re-install Windows, I've had luck with the GParted
Linux utility. You can boot from a rescue CD or from a Linux live cd to
run it. Make sure you do a backup of the hard drive first.
After you resize the partition, you may have to boot from a Windows 7 disc
and choose the repair option to make the partition bootable.
On Mon, Feb 29, 2016 at 9:48 PM, Systems Glitch via vcf-midatlantic <
> > How do I proceed?
> Frag the Windows install!
> Probably best to reinstall Windows and in the *Windows setup* bit set the
> initial partition size you want. When I dual-booted, I typically had better
> luck doing it that way than resizing.
> Thanks,
> Jonathan
