[vcf-midatlantic] Correction: Semi-OT: printer for new museum signs
Herb Johnson hjohnson at retrotechnology.info
Tue Jan 5 16:49:54 EST 2016
Evan wrote:
>  I just learned that even very cheap inkjets, sub-$200, can print 11x17.
 > That might be our best compromise if a larger printer is unaffordable.
There are a number of 11X17 inkjet printers. In fact I own an Epson
WF-7520 from two years ago which not only prints 11X17, it SCANS 11X17.
Produces PDF directly to a USB "stick". Scans both sides through the
automatic feeder. WiFi network-capable. And on sale, these printers are
near $200. New.
For the handful of signage in discussion, these are reasonably priced,
and pay for themselves in say a year. Plus one would provide local copy
and scanning capability (hint hint hint). You'll have to replace ink
carts at intervals of course, but "printing to flash" avoids a lot of
printing.
And there's laser printers too, some of which also scan, at modest
prices (but large toner costs).
Buying a larger printer is entirely a VCFed business decision, as it
would either cost more than a few hundred dollars, or would be a result
of some donation. But most signage would be 11X17 or smaller, and a
dedicated printer/scanner for that class of work, at a few hundred
dollars, would be a reasonable purchase if only to reduce use of a more
expensive printer and its no-doubt more-expensive supplies.
Translation: burn up a cuppa $200 printers instead of over-using a $1000
printer. and get a scanner while you're at it.
By the way: a long time ago, didn't InfoAge have a professional class
large printer on the premises, for large signage?
Herb
Herbert R. Johnson,  New Jersey USA
