[vcf-midatlantic] Correction: Semi-OT: printer for new museumsigns
Duane DBC1964 at cox.net
Tue Jan 5 19:11:35 EST 2016
Office Depot/Office Max has a HP 7612 on sale for $149.99. The reviews seem
to run about 4 stars out of 5
-----Original Message-----
Sent: Tuesday, January 05, 2016 6:48 PM
To: vcf-midatlantic
Cc: Corey Cohen
Subject: Re: [vcf-midatlantic] Correction: Semi-OT: printer for new
museumsigns
I have a spare network enabled HP laser jet 4plus for VCF which we can use
for printing high volume hand outs and stuff.  It can print on some pretty
heavy paper stock and is dirt cheap to run.    I just have to move it to the
new space and it even has serial so we can print from vintage machines.
The problem Evan is trying to solve is the colour signage for the museum.
If someone can recommend a good 11x17 printer, we don't need a scanner, for
around $200 or less please post an online link.
Thanks,
Corey
corey cohen
uǝɥoɔ ʎǝɹoɔ
> On Jan 5, 2016, at 5:45 PM, Dave McGuire via vcf-midatlantic
> <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>> On 01/05/2016 05:45 PM, Herb Johnson via vcf-midatlantic wrote:
>> However, a freebie B&W letter-size laser printer will print for FREE,
>> and would be a good thing to locate elsewhere.
>  I may be able to supply a B&W letter-size laser printer to VCFed.
> When everything is shaken out after Autumn and I move our work areas to
> the new building I will see what is left.  I should have at least one.
>               -Dave
> Dave McGuire, AK4HZ
> New Kensington, PA
