[vcf-midatlantic] wide printer to donate if it works/fixed at workshop
Ethan telmnstr at 757.org
Thu Jan 14 11:29:42 EST 2016
HP DesignJet 1050C printers and similar have a power supply issue where a
single cap goes bad and the printer will not power on. So if you can find
one that does not power on, just warm the PSU board with a hair dryer, it
will come on, then let it cool down, keep cutting board area in half and
you will narrow it down quickly. I want to say the bad cap sits on it's
own.
This worked for my 36" printer, and a friend got the 42" model with the 6
ink carts and same trick fixed his.
That being said, I can print stuff if you need it printed. I run expired
ink carts and heads so they're cheap, PDF/vector files best.
