[vcf-midatlantic] OT: Dell Dimension XPS 466V
Herb Johnson hjohnson at retrotechnology.info
Tue Jan 19 13:06:19 EST 2016
> Working on a Dell 486 computer.  I need a RTClock battery, but otherwise
> it's running quite nicely Windows for Workgroups 3.11
The question of batteries is on-topic IMHO.
Batteries in the long term, cause corrosion of parts that have constant
current on them. This is true all the way back to 128K Macs. also, many
batteries leak (not coin cells), that's not good either. If you add a
battery pack, make sure you can readily pull it out when the computer is
in long-term storage.
Windows for Workgroups (Win 3.1 + networking) is worth preserving. It's
a legacy OS now. It ran for many years in embedded applications (back
ATMs) and Microsoft support only ended several years ago. Many consider
Win 3.1 the first really "successful" M/S Windows OS product.
If I had time and interest, I'd see about migrating Win 3.1 to the
Heath-Zenith Z-100. That's a S-100 system that is somewhat IBM PC
compatible. I don't recall if Windows was offered for that platform,
later Zenith PC's ran even earlier Windows (I have those distributions).
Herb
Herbert R. Johnson,  New Jersey USA
