[vcf-midatlantic] OT: Dell Dimension XPS 466V
Herb Johnson hjohnson at retrotechnology.info
Wed Jan 20 12:43:18 EST 2016
As has been commented:
https://en.wikipedia.org/wiki/Windows_3.1x
"Windows 3.1 dropped real mode support and required a minimum of a 286
PC with 1 MB of RAM to run. ... Some older features were removed, like
CGA graphics support (although Windows 3.0's CGA driver still worked on
3.1) and compatibility with real mode Windows 2.x applications."
So on my Heath/Zenith Z-100 with 8088 and Z80 alternate processors, Win
3.1 would not run. But Win 1.X and 2.X may in principle work. In
practice, deciphering the hardware support might be difficult. In the
Z-100 world, various hardware products (Gemini) improved IBM PC
compatibility, those may be helpful. They won't add a 286 (generally).
In the S-100 world, there were a number of 80286 or 80288 CPU boards. I
myself have (and exhibited at VCF-E 8.0) a Compupro "8/16" system
chassis which replaced the Compupro 88/85 (dual 8088 8085 CPU) with a
Macrotech MI-286 (80286 and Z80 CPU). It ran all Compupro software
without modification. That's CP/M 80, CP/M 86, and MS-DOS. The Z-100
also runs these as Zenith products.
So THAT Macrotech system would in principle be a Windows 3.1 candidate.
if it had a video card comparable to IBM CGA (possible). If the I/O
structure was compatible. If interrupts can be handled in the IBM PC
style. If, if, if......
Win 3.1 is not a priority for me, for reasons I don't see much point in
discussing. I can understand interests in it, by the next (after me)
generation of vintage computer enthusiasts. 'Nuff said, but I might add
there's no particular hardware "target" for Win 3.1, as any legacy "100%
PC AT compatible" will do (and emulators). That does not enthuse me, as
a HARDWARE vintage computing supporter.
herb
Herbert R. Johnson,  New Jersey USA
