[vcf-midatlantic] Interesting OP-AMP Boards
Systems Glitch systems.glitch at gmail.com
Wed Jan 27 21:46:21 EST 2016
All,
These came in a lot of other plugboard/protoboard bits I picked up:
http://imgur.com/a/XUFAJ
One has two 741 OP-AMPs, the other two have a single LM311. I'm guessing from the array of hollow pins that they're meant to be wired up with some sort of banana-plug-like jumper system. I'm not sure what they're from. Some sort of analog computer or control system, perhaps? Any ideas?
They're single-sided, but everything on the back side is gold plated.
Thanks,
Jonathan
