[vcf-midatlantic] Mystery ROM from MITS 88-PMC ROM Board
Herb Johnson
hjohnson at retrotechnology.info
Fri Jan 29 16:05:25 EST 2016
> It starts with LXI SP, 0xFF13 -- a ROM location. I've seen
> the trick used elsewhere, to reduce code size by using
> an in-ROM jump table. Anyone recognize the code?
ORG 0FF00H
LXI H, 0FF13H
LXI D, 2C00H
MVI C, 0EBH
L1: MOV A,M
STAX D
INX H
INX D
DCR C
JNZ L1 ;0FF08H
JMP 2C00H
;above moves code from ROM to RAM and executes
ORG 2C00H; but code follows ROM code above at FF13H
DI
XRA A
OUT 22H
CMA
OUT 23H
MVI A, 2CH
OUT 22H
MVI A, 03H
OUT 19H
IN 0FFH
ANI 10H
RRC
RRC
ADI 10H
OUT 10H
LXI SP, 2D79H
XRA A
; next byte is at FF30H in ROM
; further disassembly should be instructive
Herbert R. Johnson, New Jersey USA
