[vcf-midatlantic] Prometheus Promodem 1200 commands
Mike Loewen
mloewen at cpumagic.scol.pa.us
Sat Jul 2 20:41:26 EDT 2016
Yes, I had found that one. Useful, but doesn't detail the settings.
I had a Promodem back in the day, but don't recall if it was 1200 or
2400. What I DO remember is that it had a heat problem and had to be run
with the top of the case removed.
On Sat, 2 Jul 2016, J. Alexander Jacocks wrote:
> Mike,
> Have you seen this page? It lists init strings for many Prometheus modems,
> including the Promodem 1200:
> http://www.modemhelp.net/p/prometheus.shtml
> I had a Promodem 2400, on my Mac SE, interestingly enough. Thanks for
> reminding me of it!
> - Alex
> On Sat, Jul 2, 2016 at 6:53 PM, Mike Loewen via vcf-midatlantic <
> vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>> The Promodem 1200 does indeed support the basic Hayes AT command set.
>> I'm looking for extended commands and Promodem specific commands. I did
>> find the Help menu (AT at H), but it doesn't go into a lot of detail. The
>> is the external Promodem 1200.
>> On Sat, 2 Jul 2016, william degnan wrote:
>> Isn't the basic AT command set the same for all modems that use AT
>>> commands? I am thinking you're looking for something promodem specific .
>>> I will check. I have one but I don't remember seeing a manual
>>> Bill Degnan
>>> twitter: billdeg
>>> vintagecomputer.net
>>> On Jul 2, 2016 5:37 PM, "Mike Loewen via vcf-midatlantic" <
>>> Does anyone have a list of AT commands for the Prometheus Promodem
>>>> 1200?
>>>> Mike Loewen mloewen at cpumagic.scol.pa.us
>>>> Old Technology http://q7.neurotica.com/Oldtech/
