[vcf-midatlantic] OT: Likely failure mode of LCD of early portable PCs, T6600C
Bill Dromgoole drummy at comcast.net
Mon Jul 4 00:06:27 EDT 2016
Some times the inverter power supply is bad.
Other times it is the cold cathode lamp in the lcd panel.
Try shining a flash light directly on the screen of the laptop.
You should be able to see the correct display very dimly.
If you can see it it means the lamp is not lit.
Could be either of the above reasons.
Inverter power supply is relatively cheap and easy to try.
The lamp is a PITA to change .I tried once but with limited sucess.
I think the whole LCD panel was ony about $60 on eBay from china.
Good luck.
  ----- Original Message -----
  To: vcf-midatlantic
  Cc: Douglas Crawford
  Sent: Sunday, July 03, 2016 8:27 PM
  Subject: [vcf-midatlantic] OT: Likely failure mode of LCD of early portable PCs, T6600C
  I have a Toshiba T6600C big laptop/small luggable PC.
  The LCD is out, but video is present on the VGA port.
  Does anyone have experience with this generation LCD screen failures...
  is it likely the screen?  Capacitor issues?  Other?
