[vcf-midatlantic] Museum Report 7/3/2016
william degnan billdegnan at gmail.com
Mon Jul 4 13:22:23 EDT 2016
There are two types of cable to use, the "buffered" and non buffered.
Depends on which model expansion unit you have.    It will say "buffered"
on it (or nothing).  BUT if it works it works regardless of what cable you
use.  It should be a 3-4 inch flat cable with female flat connector on both
sides.
b
On Mon, Jul 4, 2016 at 12:06 PM, Jeffrey Brace via vcf-midatlantic <
> OK Thanks for fixing the PET! And the PC disk! I will look for a cable in
> the warehouse for the TRS-80.
> On Sunday, July 3, 2016, william degnan via vcf-midatlantic <
> > On Sun, Jul 3, 2016 at 9:08 PM, Evan Koblentz via vcf-midatlantic <
> > vcf-midatlantic at lists.vintagecomputerfederation.org <javascript:;>>
> wrote:
> > > >> You guys are welcome to fire up the keypunch
> > > We are expanding the docent staff from five to 10ish, but I don't think
> > > there are many (any?) of us who really know how to operate it.
> > Exaggeration, I did not fix everything.
> > Basically I got the PET and the IBM PC running as requested.  I left a
> > bootable demo disk in the IBM PC that you can just turn on and go with.
> > The TRS 80 needs the buffered expansion cable that goes from the TRS 80
> > keyboard to the expansion unit.  I was not able to test the drives as a
> > result.  I also powered on a lot of the systems and checked them out.
> > I did not fix the Amiga or power it on for that matter.
> > I tested the UNIX PC.
> > @ BillDeg:
> > Web: vintagecomputer.net
> > Twitter: @billdeg <https://twitter.com/billdeg>
> > Youtube: @billdeg <https://www.youtube.com/user/billdeg>
> > Unauthorized Bio <http://www.vintagecomputer.net/readme.cfm>
@ BillDeg:
