[vcf-midatlantic] Museum Report 7/3/2016
Jeffrey Brace
ark72axow at gmail.com
Tue Jul 5 23:59:53 EDT 2016
Bill Deg Thanks so much for being docent this past Sunday! I know you come
from further that most docents, so it is much appreciated. I hope that you
are able to do it every once in a while. It is nice to have more docents in
the rotation and docents with different knowledge about the systems.
Bill Drom Thanks for working on the Univac! It is nice to have you and Bill
Deg get the museum pieces working or closer to working condition.
On Mon, Jul 4, 2016 at 1:22 PM, william degnan via vcf-midatlantic <
> There are two types of cable to use, the "buffered" and non buffered.
> Depends on which model expansion unit you have. It will say "buffered"
> on it (or nothing). BUT if it works it works regardless of what cable you
> use. It should be a 3-4 inch flat cable with female flat connector on both
> sides.
> b
> On Mon, Jul 4, 2016 at 12:06 PM, Jeffrey Brace via vcf-midatlantic <
> > OK Thanks for fixing the PET! And the PC disk! I will look for a cable in
> > the warehouse for the TRS-80.
> > On Sunday, July 3, 2016, william degnan via vcf-midatlantic <
> > > On Sun, Jul 3, 2016 at 9:08 PM, Evan Koblentz via vcf-midatlantic <
> > > vcf-midatlantic at lists.vintagecomputerfederation.org <javascript:;>>
> > wrote:
> > > > >> You guys are welcome to fire up the keypunch
> > > > We are expanding the docent staff from five to 10ish, but I don't
> think
> > > > there are many (any?) of us who really know how to operate it.
> > > Exaggeration, I did not fix everything.
> > > Basically I got the PET and the IBM PC running as requested. I left a
> > > bootable demo disk in the IBM PC that you can just turn on and go with.
> > > The TRS 80 needs the buffered expansion cable that goes from the TRS 80
> > > keyboard to the expansion unit. I was not able to test the drives as a
> > > result. I also powered on a lot of the systems and checked them out.
> > > I did not fix the Amiga or power it on for that matter.
> > > I tested the UNIX PC.
> > > @ BillDeg:
> > > Web: vintagecomputer.net
> > > Twitter: @billdeg <https://twitter.com/billdeg>
> > > Youtube: @billdeg <https://www.youtube.com/user/billdeg>
> > > Unauthorized Bio <http://www.vintagecomputer.net/readme.cfm>
> @ BillDeg:
