[vcf-midatlantic] OT: Maintenance around 9010-A & 9036A
Herb Johnson hjohnson at retrotechnology.info
Mon Jul 18 22:09:00 EDT 2016
While InfoAge grounds maintenance is a good idea, you might consider
that most of New Jersey has been under high-temp, high-humidity alerts,
and thunderstorms alerts, through this summer. Consider scheduling such
work in the spring or fall. - Herb
Herbert R. Johnson,  New Jersey USA
