[vcf-midatlantic] DOS question
Bill Sudbrink wh.sudbrink at verizon.net
Tue Jul 19 13:32:58 EDT 2016
Evan Koblentz wrote:
> I'm using a Compaq 386. Rather than typing CD DOS every time that I
> need to run a program (BASICA) in the DOS directly, how can I create a
> shortcut that loads on boot to let me type BASICA at the C:\ prompt and
> have it run automatically? Also, is there a shortcut I can use (for
> example in autoexec.bat or config.sys) to make Caps Lock automatically
> enable on boot?
My old brain cells tell me that the PATH environment variable
should do what you want.
PATH=C:\DOS
