[vcf-midatlantic] DOS question
Jason Perkins perkins.jason at gmail.com
Tue Jul 19 14:09:00 EDT 2016
If you don't have edit, and are sure of your typing you can just use a
file redirect with echo, for example:
echo Why hello my name is Jason >> jason.txt
will create the file jason.txt if it doesn't exist, and add that line
to the end. A single > overwrites the file, a double >> appends to the
end.
Note that you can use the file redirector with the output of any text program.
-J
On Tue, Jul 19, 2016 at 1:56 PM, Evan Koblentz via vcf-midatlantic
<vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>>> may have to use edlin if you don't have edit
> No clue how to use that.
Jason Perkins
313 355 0085
