[vcf-midatlantic] TRS-80 PC-1 & Printer
Dean Notarnicola
dnotarnicola at gmail.com
Thu Jul 28 15:38:29 EDT 2016
*From the past...*[vcf-midatlantic] Repair TRS-80 pocket computer screen
Click to teach Gmail this conversation is important.
Inbox
x
VCF
x
Christopher Blackmon via vcf-midatlantic
{no text body}
Jun 2
{no text body}
Jonathan Gevaryahu via vcf-midatlantic
Bleeding 'ink', like a black ring which is converging toward the center of
th...
Jun 2
th...
Jonathan Gevaryahu via vcf-midatlantic <
vcf-midatlantic at lists.vintagecomputerfederation.org>
Jun 2
to *Jonathan*, Christopher
the lcd? or squiggly lines of black 'ink' coming from one edge? In either
case that's irrepairable, you're going to need a replacement lcd for that.
Jonathan Gevaryahu
jgevaryahu at gmail.com
jgevaryahu at hotmail.com
Reply
Reply to all
Forward
Corey Cohen via vcf-midatlantic <
Jun 2
to *Corey*, Christopher
> On Jun 2, 2016, at 1:05 PM, Christopher Blackmon <ckblackm at yahoo.com>
wrote:
> Does anyone know how to repair/replace the screen on a TRS-80 pocket
computer?
> It looks like the edges of the screen are bleeding ink or something.
> Christopher.
Replacing is a pain because you need to find a replacement glass. There
are some people who have split the screen, cleaned it and reassembled.
Personally it seems a daunting task to me.
I'd locate another unit and use your current one for parts. When you get
the new unit, open it up and using aquarium silicon sealer to run a bead
around the edge of the LCD display so that it stays sealed. The PC-1 has
an early LCD screen and the seals can dry out and then start the LCD
bleeding process. Sealing the LCD should prevent the issue. I have done
this to my PC-1 and have no bleeding or issues.
Cheers,
Corey
corey cohen
uǝɥoɔ ʎǝɹoɔ
Reply
Reply to all
Forward
Evan Koblentz via vcf-midatlantic <
Jun 2
to *Evan*
>> computer?
>> Christopher.
When seeking another PC-1, remember it's only a Sharp PC-1211 in TRS
disguise.
On Thu, Jul 28, 2016 at 3:34 PM, Evan Koblentz via vcf-midatlantic <
> I just picked up this system, and the screen is practically unusable. Does
>> anyone know if there is a way to repair this kind of damage on the old LCD
>> screens.
> I think we had a similar discussion here not long ago.
