[vcf-midatlantic] TRS-80 PC-1 & Printer
Joseph Oprysko
joprysko1 at gmail.com
Thu Jul 28 16:39:50 EDT 2016
I completely forgot that you can't send pictures to the listserv. Which I
blatantly did. It is the bleeding ink problem.
It's a TRS-80 PC-1, aka Sharp 1211. From the repair manual I found online,
the part number of the display is LF8017JE, but a quick google search of
that display brings up absolutely nothing.
On Thursday, July 28, 2016, Evan Koblentz via vcf-midatlantic <
> As far as batteries go, replacing NiCd packs isn't particularly hard, as
>> most are made of standard cells. Batteries Plus has been known to make up
>> custom packs, at customer request, as well.
> That's where I went for the IBM Simon battery. They welded together a
> custom pack for me. It worked great.
Normal Person: Hey, it seems that you know a lot.
Geek: To be honest, it's due to all the surfing I do.
Normal Person: So you go surfing?
Normal Person: But I don't think that has anything to do with knowing a
lot...
Geek: I think that's wrong on a fundamental level.
Normal Person: Huh? Huh? What?
