[vcf-midatlantic] TRS-80 PC-1 & Printer
Herb Johnson
hjohnson at retrotechnology.info
Fri Jul 29 14:31:35 EDT 2016
David Gesswein posted:
> I would always recommend opening up and checking anything you know has a
> battery in it. They frequently leak which will damage whatever is nearby.
> Nicads leakage seems to be less volume than some other types.
> Powering it up with the leakage would likely make things worse.
There's many kinds of batteries inside vintage electronics; it's useful
in my opinion to identify what you have. Generally you should not
replace one kind with another kind. I'll walk through reasons - do your
homework before serious work. I won't discuss lead cells or gel-cells.
NI-cd's or Nicads work at different voltages than Nickel-hydride which
is the more recent alternative. Lithium cells are usually very small
batteries. Leakage is a problem, among other problems.
Nicads have a longer shelf life, can be completely discharged but still
are rechargable - good for those solar yard-lights. They usually don't
leak, but do corrode and produce a flaky material. You can still obtain
NiCd batteries, for equipment which may sit for months and then be put
back to service. Also: when you want the same voltage from the same
number of battery cells (say a NICd 12V pack).
Nickel-metal-hydride or NiMH don't like to be completely discharged.
They are more common these days of course, and have more power in a
smaller package.
Lithium batteries were used for years in vintage computers, as clock and
data backup power in tiny cells (Apple Macintosh computers). I believe
many of the coin-cells are lithium. They are not rechargable, they have
a VERY long shelf life. But the cylindrical-type (look like fractional
AAA or AA batteries) sometimes leak, and when they do it's a gooey
awful mess. The 1990 lithium removable cells, seem to leak more than the
1980's wired-in lithium cells. They have specific voltages per cell and
package, so pay attention to both when replacing.
A side issue: the constant voltage from these batteries, produces copper
corrosion - that green powder stuff - on circuits. I see chips and PC
boards with green on them. Not good, and scrubbing off the copper oxide
just reveals bare copper which will corrode unless coated with
something. Frankly- I advice removing these batteries from any computer,
when you can operate it without one. Install it when using, if you
insist on the correct date or have BIOS settings, etc.
All part of the fun of vintage computer repair. I enjoy the challenges
and finding problems and fixes and work-arounds. That calls for
understanding the fundamentals. That's how I work....
Herb Johnson
Herbert R. Johnson, New Jersey USA
