[vcf-midatlantic] Retr0brite chemistry (was: Re: apple // monitor)
Jason Perkins perkins.jason at gmail.com
Sun Jul 31 08:04:01 EDT 2016
I've used the salon creme, the 40% stuff, with good results. The key is to
leave it on for just a bit, then wash it off and check the piece. Also know
that non white / beige plastic goes at a different rate.
I do know that without uv light the creme does nothing.
-J
On Jul 31, 2016 12:55 AM, "Tony Bogan via vcf-midatlantic" <
> I don't actually use retrobrite, but the salon creme, which in my
> experience is not as harsh (at least to date, only true length of time will
> tell!)
> Regardless, thank you for the heads up, I am aware of that thread and the
> controversies/debates surrounding the process. Sometimes it's fun just to
> sit back and watch the threads on various forums go back and forth about
> the process!!
> Tony
> Sent from my iPhone
> > On Jul 31, 2016, at 12:52 AM, Jonathan Gevaryahu via vcf-midatlantic <
> >> On 7/31/2016 12:42 AM, Tony Bogan via vcf-midatlantic wrote:
> >> Green screen or color? I have enough monitor IIs (green phosphor) I can
> definitely give you one (you'll have to live with some yellowing, haven't
> retrobrighted them yet)
> > Before retr0briting anything, take a look at this reddit thread, which
> examines the actual chemistry behind it.
> https://www.reddit.com/r/gamecollecting/comments/4pdwhw/my_theory_on_retr0bright/
> > TL/DR: New theory is peroxide in retr0brite just eats/degrades the
> outside layer of ABS (including the broken-down, discolored layer, making
> it appear lighter again), doesn't actually 'fix' anything, and the brown
> color has to do with the way ABS decays, has little or nothing to do with
> brominated fire retardants.
> > Jonathan Gevaryahu
> > jgevaryahu at gmail.com
> > jgevaryahu at hotmail.com
