[vcf-midatlantic] FS: Tektronix/Sony 308 Data Analyzer (Logic Analyzer)
Systems Glitch systems.glitch at gmail.com
Sat Jun 4 20:35:37 EDT 2016
link: http://www.ebay.com/itm/272264216556
Fully functional, just selling it as I've finally got my HP 1650A logic analyzer set up and checked out. I've used this little logic analyzer a number of times in both vintage computer and embedded microcontroller work. It comes with the P6451 pod, which allows both 8-bit parallel data acquisition and serial analysis. Full flying lead and grabber kit included -- you can plug the flying leads onto AP/3M "DIP clips", standard pin headers (like an IDE header), wire wrap pins, or into the grabbers. Instruction manual is included, as well as an IEC power cable and the protective front panel cover.
This unit can be expanded with a word recognizer pod, which allows input from 16 possible inputs to trigger data collection. This can be used to trigger when, for example, an 8-bit CPU hits a certain address. The auction does *not* include a word recognizer pod.
As with all listings, if you'd like to save on shipping by having me bring this to the next VCF workshop event I'm able to attend, that's fine!
Thanks,
Jonathan
