[vcf-midatlantic] Happiness is...
Jonathan Gevaryahu jgevaryahu at gmail.com
Thu Jun 9 22:12:06 EDT 2016
You may want to replace all electrolytic caps on the hdd before powering
it up, should at least somewhat increase your chances of success.
You might also want to test the tantalum caps to be sure none are shorted.
On 6/9/2016 10:03 PM, Mike Loewen via vcf-midatlantic wrote:
> On Thu, 9 Jun 2016, william degnan wrote:
>> Any 8 in. Tandy system that works is good news
>    I had the Model II fired up a couple of weeks ago.  A guy up near
> Toronto needed a couple of system disks to check out his newly
> acquired Model II.  I booted up TRS-DOS 2.0a, Pickles & Trout CP/M,
> and LS-DOS 6.3.1.
>    I still haven't tested the 8MB hard drive for it, but am almost
> certain it won't work.  :-)
> Mike Loewen                mloewen at cpumagic.scol.pa.us
> Old Technology                http://q7.neurotica.com/Oldtech/
Jonathan Gevaryahu
jgevaryahu at hotmail.com
