[vcf-midatlantic] What's this part called?
Evan Koblentz evan at snarc.net
Mon Jun 13 18:25:42 EDT 2016
>> No, that's a 16-bit version for the Model 30 286. Unless you're working on a Model 30 286 it won't work at all. Beware, there are two risers for the Model 30 -- one with ISA slots, and one with just a RTC battery and no slots.
Hmmm.
I don’t see a place for a second riser on the motherboard.
Also the CPU says 8086 on it, not 80286.
Could this be an earlier board in a Model 30 case? What's going on here??
