[vcf-midatlantic] Capacitor list for Mac 128/512/plus Analog board (US Version)
Matt Patoray mspproductions at gmail.com
Wed Jun 29 21:40:39 EDT 2016
Well,
It looks like the list does not allow PDF's.
Here is the list in text.
Electrolytic Capacitor List for Macintosh 128K/512k/512Ke/Plus
Value        Volt    Type        QU    Mouser Part #            Man
Temp  New V
____________________________________________________________________________
3.3     UF    16    Axial Lytic    2    594-2222-021-38338        Vis
 85    63
22    UF    50    Axial Lytic    2    594-2222-138-38229        Vis
 105    63
47    UF    10    Axial Lytic    1    594-2222-138-35479        Vis
 105    16
10    UF    160    Lytic        1    647-UPW2D100MPD        Nic     105
200
100    UF    200    Lytic        2    667-ECA-2EHG101        Pan     105
250
220    UF    16    Lytic        2    667-EEU-FC1E221        Pan     105
25
470    UF    16    Lytic        2    667-EEU-FC1E471L        Pan     105
25
1000    UF    16    Lytic        3    667-EEU-HD1E102B        Pan
 105    25
2200    UF    16    Lytic Low Imp    2    647-UHW1E222MHD        Nic
 105    25
4700    UF    16    Lytic        1    647-UPW1E100MDD1TD     Nic     105
25
On Wed, Jun 29, 2016 at 9:28 PM, Jonathan Gevaryahu via vcf-midatlantic <
> On 6/29/2016 9:13 PM, Matt Patoray via vcf-midatlantic wrote:
>> I thought this might be of help to some trying to do a bulk replacement of
>> capacitors on the Analog boards form the early macs. Where possible i went
>> with 105 degree rated capacitors and with a 25% higher voltage rating. The
>> part numbers are from Mouser.
> Attachment missing.
> Jonathan Gevaryahu
> jgevaryahu at gmail.com
> jgevaryahu at hotmail.com
Matt Patoray
Owner, MSP Productions
(330)718-3064 (mobile)
KD8AMG Amateur Radio Call Sign
