[vcf-midatlantic] Capacitor list for Mac 128/512/plus Analog board (US Version)
Joseph Oprysko
joprysko1 at gmail.com
Wed Jun 29 22:00:41 EDT 2016
While I'm not have any issues with my 128 & 512, would you recommend
re-capping?
On Wednesday, June 29, 2016, Matt Patoray via vcf-midatlantic <
> Well,
> It looks like the list does not allow PDF's.
> Here is the list in text.
> Electrolytic Capacitor List for Macintosh 128K/512k/512Ke/Plus
> Value Volt Type QU Mouser Part # Man
> Temp New V
> ____________________________________________________________________________
> 3.3 UF 16 Axial Lytic 2 594-2222-021-38338 Vis
> 85 63
> 22 UF 50 Axial Lytic 2 594-2222-138-38229 Vis
> 105 63
> 47 UF 10 Axial Lytic 1 594-2222-138-35479 Vis
> 105 16
> 10 UF 160 Lytic 1 647-UPW2D100MPD Nic 105
> 200
> 100 UF 200 Lytic 2 667-ECA-2EHG101 Pan 105
> 250
> 220 UF 16 Lytic 2 667-EEU-FC1E221 Pan 105
> 25
> 470 UF 16 Lytic 2 667-EEU-FC1E471L Pan 105
> 25
> 1000 UF 16 Lytic 3 667-EEU-HD1E102B Pan
> 105 25
> 2200 UF 16 Lytic Low Imp 2 647-UHW1E222MHD Nic
> 105 25
> 4700 UF 16 Lytic 1 647-UPW1E100MDD1TD Nic 105
> 25
> On Wed, Jun 29, 2016 at 9:28 PM, Jonathan Gevaryahu via vcf-midatlantic <
> vcf-midatlantic at lists.vintagecomputerfederation.org <javascript:;>> wrote:
> > On 6/29/2016 9:13 PM, Matt Patoray via vcf-midatlantic wrote:
> >> I thought this might be of help to some trying to do a bulk replacement
> of
> >> capacitors on the Analog boards form the early macs. Where possible i
> went
> >> with 105 degree rated capacitors and with a 25% higher voltage rating.
> The
> >> part numbers are from Mouser.
> > Attachment missing.
> > Jonathan Gevaryahu
> > jgevaryahu at gmail.com <javascript:;>
> > jgevaryahu at hotmail.com <javascript:;>
> Matt Patoray
> Owner, MSP Productions
> (330)718-3064 (mobile)
> mspproductions at gmail.com <javascript:;>
> KD8AMG Amateur Radio Call Sign
Normal Person: Hey, it seems that you know a lot.
Geek: To be honest, it's due to all the surfing I do.
Normal Person: So you go surfing?
Normal Person: But I don't think that has anything to do with knowing a
lot...
Geek: I think that's wrong on a fundamental level.
Normal Person: Huh? Huh? What?
