[vcf-midatlantic] More about the STK library
Evan Koblentz
evan at snarc.net
Mon Mar 7 15:21:12 EST 2016
>> Looks like we'll definitely have to reference cloud storage on the sign.
>> I am fine with that because the prevalence of LTE + WiFi make many TBs
>> of storage * essentially * local/personal to your phone.
> That's many TBs of *someone else's* storage. Despite corporations'
> heavy attempts to train the general uneducated public that there's no
> difference, you and I know that the distinction is critical.
> One thing I had thought to do with that tape juke is to use a sheet
> metal nibbler to cut a "window" in the main door, put some lucite/plexi
> in there with a rubber surround to make it look good, then write some
> code to move the tape picker around inserting/rearranging tapes.
Right. That's why Steve A. and I were trying to open the door without
having the key yesterday. :) Wanted to figure out where the window
should be.
This unit has the optional expansion door on the left side, so if the
robot is * behind * all those extra slots then a window may not make
any difference.
> to anyone but the most clueless PC person, and they're not terribly rare
> either.
Heh... I know you meant "they" being the libraries, because "not
terribly rare" re: clueless PC persons is an understatement. :)
> But most people are never in an environment where such things are in
> use, so it'd be a new experience to see one batting its positioner around.
Exactly.
