[vcf-midatlantic] (Delayed) pictures from yesterday
Brian L. Stuart blstuart at bellsouth.net
Tue Mar 15 16:02:31 EDT 2016
> I would advise caution in the selection of material. If you get something
> relatively fine-woven it will be a lot less likely to collect dust, though
> relative immunity from static buildup helps there too (and is probably a
> good idea anyway, considering the nature of the collection, heh!)
I'd also suggest getting a sample and doing some test photography
with it.  There are some fabrics that flashes go through in such a
way that the fabric almost becomes transparent.  The photograph
of me receiving my bachelor's degree has a really bizzare effect
from the cheap rental robe where it appears you can see right
through my leg.
BLS
