[vcf-midatlantic] (Delayed) pictures from yesterday
Dean Notarnicola
dnotarnicola at gmail.com
Tue Mar 15 16:17:47 EDT 2016
Fabric on walls WILL collect dust. Short straw gets to vacuum the walls...
On Tuesday, March 15, 2016, Brian L. Stuart via vcf-midatlantic <
> > I would advise caution in the selection of material. If you get something
> > relatively fine-woven it will be a lot less likely to collect dust,
> though
> > relative immunity from static buildup helps there too (and is probably a
> > good idea anyway, considering the nature of the collection, heh!)
> I'd also suggest getting a sample and doing some test photography
> with it. There are some fabrics that flashes go through in such a
> way that the fabric almost becomes transparent. The photograph
> of me receiving my bachelor's degree has a really bizzare effect
> from the cheap rental robe where it appears you can see right
> through my leg.
> BLS
