[vcf-midatlantic] DEC serial console cable wanted
VAXman at tmesis.org VAXman at tmesis.org
Fri Mar 18 11:33:40 EDT 2016
David Riley via vcf-midatlantic writes:
>On Mar 18, 2016, at 10:46 AM, Jameel Akari via vcf-midatlantic =
><vcf-midatlantic at lists.vintagecomputerfederation.org> wrote: >=20 > That
>said, does anyone have an MMJ crimper they could bring to VCF?  = And I
>good source for the connectors themselves?
>Yes and yes.  I brought mine last year (have dies for MMJ and standard =
>8p8c as well as standard 6p6c and various wire terminal crimpers), and =
>will bring again.  I have pretty full bags of MMJ and both solid and =
>stranded 8p8c plugs.
>For the connectors, they're actually surprisingly easy to come across.
>= For example:
>http://www.pacificcable.com/Picture_Page.asp?DataName=3DMMJ = or =
>http://www.neobits.com/pan_pacific_pt_066dec_rj_11_mmj_dec_plugs_qty_100_p=
>3962335.html?atc=3Dgbp&gclid=3DCImikZTDyssCFYclgQodjdQPQA (I've used =
>Pacific, but the other one is probably just as good for $10 less).
>If you have a Paladin Crimp-All 8000 frame (and you should, because it's
>= a great tool), the Paladin die for MMJ is 2067.
I do, I do!
