[vcf-midatlantic] Posts not showing
Dan Roganti ragooman at gmail.com
Tue Mar 22 21:21:30 EDT 2016
On Tue, Mar 22, 2016 at 9:16 PM, Jeffrey Brace via vcf-midatlantic <
> The problem with not getting your own posts is that you don't know if it
> was successful. So I used to end up posting the same message again because
> I didn't know if it got through or not. So now do I have to ask everyone if
> they got it? And thereby generate more e-mail?
​if there is some worry about whether the post made it to the mailing list,
you can go check the archive​ here to see if it's been recorded.
If it's on there, you can be rest assured it has been distributed to all of
the subscribers
whether they have read it or not is a whole different issue :)
http://lists.vintagecomputerfederation.org/pipermail/vcf-midatlantic/
Dan
