[vcf-midatlantic] Posts not showing
Dean Notarnicola dnotarnicola at gmail.com
Tue Mar 22 21:23:27 EDT 2016
Agreed. I use gmail and I have never missed a post.
On Tuesday, March 22, 2016, Dan Roganti via vcf-midatlantic <
> On Tue, Mar 22, 2016 at 9:16 PM, Jeffrey Brace via vcf-midatlantic <
> vcf-midatlantic at lists.vintagecomputerfederation.org <javascript:;>> wrote:
> > The problem with not getting your own posts is that you don't know if it
> > was successful. So I used to end up posting the same message again
> because
> > I didn't know if it got through or not. So now do I have to ask everyone
> if
> > they got it? And thereby generate more e-mail?
> ​if there is some worry about whether the post made it to the mailing list,
> you can go check the archive​ here to see if it's been recorded.
> If it's on there, you can be rest assured it has been distributed to all of
> the subscribers
> whether they have read it or not is a whole different issue :)
> http://lists.vintagecomputerfederation.org/pipermail/vcf-midatlantic/
> Dan
