[vcf-midatlantic] VT320 CRT replacement?
David Riley
fraveydank at gmail.com
Mon May 2 17:11:27 EDT 2016
On May 2, 2016, at 4:55 PM, Ian Primus via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
> On Mon, May 2, 2016 at 4:47 PM, David Riley via vcf-midatlantic
>> Yes, all I meant to say is that to my understanding, it's similarly temporary, > and the effect of a rejuvenator on a CRT tends to revert similarly quickly.
> It can be, but, what it's really doing is burning off the outer
> coating of the cathode, and exposing more emissible material. This can
> be temporary, depending on tube construction, but it's been my
> experience that most mono tubes take to it very well and hold up
> nicely. Some tubes, notably Sony color tubes... don't rejuvinate. Not
> at all. And some, like 90's era Zenith tubes as used in some arcade
> monitors - will revert within a week of use. But I've got mono tubes
> I've zapped that are still fine, years later.
Hm, worth a shot, anyway. I've always been puzzled about the reversion mechanism; it doesn't make a lot of sense from a chemical or physical standpoint unless the tube is a little gassed (in which case I'd expect other problems).
I don't know a thing about rejuvenators, but it seems like the B&K 440 is widely available for decent prices on eBay. Would that be suitable for a mono tube?
- Dave
-------------- next part --------------
A non-text attachment was scrubbed...
Type: application/pgp-signature
Desc: Message signed with OpenPGP using GPGMail
URL: <https://lists.vcfed.org/pipermail/vcf-midatlantic/attachments/20160502/a1817a1e/attachment.sig>
