[vcf-midatlantic] (Semi-off topic) Looking for a place in NJ that does in-place expandable foam packing.
william degnan
billdegnan at gmail.com
Sat May 7 13:38:11 EDT 2016
> >I've used Insta-Pak RT for shipping very delicate/expensive electronics
> and lab equipment in the past -- I'm currently out and need to order more.
> It's excellent packing material, a little expensive, but not so expensive
> if you consider the risk it avoids! I buy mine through ULINE. Make sure to
> get the Insta-Pak *RT* variety -- RT indicates "Room Temperature," the
> cheaper Insta-Pak requires a heating plate or it won't activate.
> >Thanks,
> >Jonathan
I shipped a TRS 80 model 3 by filling the box that chocolate syrup that
hardens when it cools. Makes a perfect mold. I have not yet heard back
from the guy but I bet it worked perfectly. If you're going to do that with
an Apple 1, you should probably shrink wrap it first, it might be hard to
spray off all of that chocolate.
@ BillDeg:
Web: vintagecomputer.net
Twitter: @billdeg <https://twitter.com/billdeg>
Youtube: @billdeg <https://www.youtube.com/user/billdeg>
Unauthorized Bio <http://www.vintagecomputer.net/readme.cfm>
