[vcf-midatlantic] (Semi-off topic) Looking for a place in NJ that does in-place expandable foam packing.
David Riley
fraveydank at gmail.com
Sat May 7 14:51:42 EDT 2016
On May 7, 2016, at 12:22 PM, Systems Glitch via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
> I've used Insta-Pak RT for shipping very delicate/expensive electronics and lab equipment in the past -- I'm currently out and need to order more. It's excellent packing material, a little expensive, but not so expensive if you consider the risk it avoids! I buy mine through ULINE. Make sure to get the Insta-Pak *RT* variety -- RT indicates "Room Temperature," the cheaper Insta-Pak requires a heating plate or it won't activate.
I've actually been meaning to ask in case anyone knows: is there a benefit to the non-RT one? Seems to me that if there wasn't, they'd only sell the RT. Is it more elastic, cheaper, etc.?
- Dave
-------------- next part --------------
A non-text attachment was scrubbed...
Type: application/pgp-signature
Desc: Message signed with OpenPGP using GPGMail
URL: <https://lists.vcfed.org/pipermail/vcf-midatlantic/attachments/20160507/2f5c7bf6/attachment.sig>
