[vcf-midatlantic] (Semi-off topic) Looking for a place in NJ that does in-place expandable foam packing.
Corey Cohen
applecorey at optonline.net
Sat May 7 15:54:26 EDT 2016
With instapak RT, how do I know what size to order. Do you order the exact size of your box or bigger?
corey cohen
uǝɥoɔ ʎǝɹoɔ
> On May 7, 2016, at 2:51 PM, David Riley via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>> On May 7, 2016, at 12:22 PM, Systems Glitch via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>> I've used Insta-Pak RT for shipping very delicate/expensive electronics and lab equipment in the past -- I'm currently out and need to order more. It's excellent packing material, a little expensive, but not so expensive if you consider the risk it avoids! I buy mine through ULINE. Make sure to get the Insta-Pak *RT* variety -- RT indicates "Room Temperature," the cheaper Insta-Pak requires a heating plate or it won't activate.
> I've actually been meaning to ask in case anyone knows: is there a benefit to the non-RT one? Seems to me that if there wasn't, they'd only sell the RT. Is it more elastic, cheaper, etc.?
> - Dave
