[vcf-midatlantic] German Nixdorf 820 Brochure
Ben Greenfield
ben at cogs.com
Wed May 18 10:53:53 EDT 2016
It’s a up.
This folder contains the original brochure as pdf, the german text and the english text.
I will now start to clean up the text files.
Thanks all of the help.
Ben
> On May 18, 2016, at 10:46 AM, Ben Greenfield via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
> From: Ben Greenfield <ben at cogs.com>
> Subject: Re: [vcf-midatlantic] German Nixdorf 820 Brochure
> Date: May 18, 2016 at 10:46:12 AM EDT
> To: vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org>
>> On May 18, 2016, at 10:35 AM, Herb Johnson via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>> Google Translate does adequate translation from many languages including german, if given clean ASCII text. You can likely clean up the result. Of course...google "google translate" for access. I find it convenient to have the document online, so I can present Google Translate the Web link.
> I will give a try.
> I was able to copy and paste the text out of preview and posted it here
> http://projects.cogs.com/Nixdorf820/
> I will give google translate a try.
> Ben
>> Herb
>> Herbert R. Johnson, New Jersey USA
>> http://www.retrotechnology.com OR .net
>> preservation of 1970's computing
>> email: hjohnson AAT retrotechnology DOTT com
>> alternate: herbjohnson ATT retrotechnology DOTT info
