[vcf-midatlantic] OT: One modern PC, two screens
David Hoelzer dhoelzer at enclaveforensics.com
Thu May 19 10:53:10 EDT 2016
The dump is another great spot to go. Electronics typically go in a separate pile because they’re hazardous. I can’t tell you how many wonderful monitors I’ve snagged out of the goody pile at the dump.
> On May 19, 2016, at 10:24 AM, Dean Notarnicola via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
> Agreed. Garage sales are the way to go. I see them very often for the same
> prices that Ian does.​
> On Thu, May 19, 2016 at 10:19 AM, Ian Primus via vcf-midatlantic <
>> On Thu, May 19, 2016 at 10:06 AM, Evan Koblentz via vcf-midatlantic
>>> Ian, where are these nearly free monitors? :)  Cheapest I'm seeing on NJ
>>> Craiglist are $50-$100.
>> Every other garage sale I go to seems to have an LCD monitor,
>> keyboard, and mouse, but no computer. Usually on the order of ten
>> years old - but sometimes quite a bit newer. I have seen several of
>> those wide format monitors too. Don't think I've seen a single one
>> priced more than $10 or $20. If I had a desire to switch to LCD
>> monitors, there sure are a lot of them around. Found a nice Mitsubishi
>> CRT for $5 though, so it's not been all LCDs.
>> -Ian
-------------- next part --------------
A non-text attachment was scrubbed...
Type: application/pgp-signature
Desc: Message signed with OpenPGP using GPGMail
URL: <https://lists.vcfed.org/pipermail/vcf-midatlantic/attachments/20160519/aec90f3f/attachment.sig>
