[vcf-midatlantic] ADTPro help
Neil Cherry ncherry at linuxha.com
Tue May 24 13:49:10 EDT 2016
On 05/24/2016 01:42 PM, Evan Koblentz wrote:
>> Chris is correct Java cares about 64 and 32 bit os libraries.
>> Evan do a"
>> uname -a
>> java -version
> Output:
> Linux evan-desktop 3.13.0-86-generic #131-Ubuntu SMP Thu May 12 23:32:41 UTC 2016 i686
> athlon i686 GNU/Linux
Okay Linux is 32 bit, so it wants 32 bit libraries.
Still need the java version:
java -version
What type of serial port are you using the PC's builtin serial, a usb serial
or something else ?
I saw a note where ADTPro gets upset if the serial port is missing (you should
see something from the dmesg command).
Linux Home Automation         Neil Cherry       ncherry at linuxha.com
http://www.linuxha.com/                         Main site
http://linuxha.blogspot.com/                    My HA Blog
Author of:    	Linux Smart Homes For Dummies
