[vcf-midatlantic] ADTPro help
Evan Koblentz
evan at snarc.net
Tue May 24 14:44:10 EDT 2016
>> I saw a note where ADTPro gets upset if the serial port is missing (you should
>> see something from the dmesg command).
> Is your user account a member of the "dialout" group? It not, you will need to use sudo to access serial ports on Linux.
> David
I'm not sure how to check, but my account = admin, so it should have
full privileges to everything. Anyway I tried running adtpro as sudo
from a terminal and got the same error.
