[vcf-midatlantic] ADTPro help
Kelly Leavitt kelly at catcorner.org
Tue May 24 14:55:50 EDT 2016
 On May 24, at 2:48 PM David Ryskalcyk wrote:
 > On May 24, 2016, at 2:39 PM, Kelly Leavitt via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
> > Win10 x64 and Mint x64 both. This was with a prolific usb to serial adapter on an older i7 machine and the same on an i5 dell laptop running Linux.
> It's possible you have a counterfeit Prolific USB-serial adapter. Does it work with the latest Prolific drivers on Windows 10? The older fakes would produce a "Code 10" error; the newer ones may not.
>I've had success with FTDI and Silicon Labs, as well as genuine Prolific adapters, but the fakes are of varying quality and don't always work.
It's a real one. This adapter works everywhere, it only seems to have problems with the Java lib. I use this in everything from Windows XP to my Rasperry PI. I purchased a dozen for the local radio club and still have a couple of my own.
I used the same adapter several years ago with the same setup and didn't have this problem. This was under Windows 7 back when ADTPro was only verified to work under java32.
Kelly
