[vcf-midatlantic] ADTPro help
J. Alexander Jacocks jjacocks at gmail.com
Tue May 24 15:19:41 EDT 2016
In Evan's case, he is using a 32bit installation, since his previous
processor was x86.  So, there should not be any problems with the library
version.
I can't help this evening (I have a business dinner engagement), but I can
certainly help on the 12th, if the issue persists.
- Alex
On Tue, May 24, 2016 at 2:55 PM, Kelly Leavitt via vcf-midatlantic <
>  On May 24, at 2:48 PM David Ryskalcyk wrote:
>  > On May 24, 2016, at 2:39 PM, Kelly Leavitt via vcf-midatlantic <
> > > Win10 x64 and Mint x64 both. This was with a prolific usb to serial
> adapter on an older i7 machine and the same on an i5 dell laptop running
> Linux.
> > It's possible you have a counterfeit Prolific USB-serial adapter. Does
> it work with the latest Prolific drivers on Windows 10? The older fakes
> would produce a "Code 10" error; the newer ones may not.
> >I've had success with FTDI and Silicon Labs, as well as genuine Prolific
> adapters, but the fakes are of varying quality and don't always work.
> It's a real one. This adapter works everywhere, it only seems to have
> problems with the Java lib. I use this in everything from Windows XP to my
> Rasperry PI. I purchased a dozen for the local radio club and still have a
> couple of my own.
> I used the same adapter several years ago with the same setup and didn't
> have this problem. This was under Windows 7 back when ADTPro was only
> verified to work under java32.
> Kelly
