[vcf-midatlantic] ADTPro help
Neil Cherry
ncherry at linuxha.com
Tue May 24 15:14:52 EDT 2016
On 05/24/2016 02:44 PM, Evan Koblentz via vcf-midatlantic wrote:
>>> I saw a note where ADTPro gets upset if the serial port is missing (you should
>>> see something from the dmesg command).
>> Is your user account a member of the "dialout" group? It not, you will need to use sudo
>> to access serial ports on Linux.
>> David
> I'm not sure how to check, but my account = admin, so it should have full privileges to
> everything. Anyway I tried running adtpro as sudo from a terminal and got the same error.
at the command line type:
id
Linux Home Automation Neil Cherry ncherry at linuxha.com
http://www.linuxha.com/ Main site
http://linuxha.blogspot.com/ My HA Blog
Author of: Linux Smart Homes For Dummies
