[vcf-midatlantic] ADTPro help
Evan Koblentz evan at snarc.net
Tue May 24 15:47:40 EDT 2016
> * Run it in the console, give us the complete output
Ran it as sudo. Got this:
Java HotSpot(TM) Server VM warning: You have loaded library
/home/evan/ADTPro-2.0.1/lib/rxtx/rxtx-2.2pre2-local/x86_64-unknown-linux-gnu/librxtxSerial.so
which might have disabled stack guard. The VM will try to fix the stack
guard now.
It's highly recommended that you fix the library with 'execstack -c
<libfile>', or link it with '-z noexecstack'.
java.lang.UnsatisfiedLinkError:
/home/evan/ADTPro-2.0.1/lib/rxtx/rxtx-2.2pre2-local/x86_64-unknown-linux-gnu/librxtxSerial.so:
wrong ELF class: ELFCLASS64 (Possible cause: architecture word width
mismatch) thrown while loading gnu.io.RXTXCommDriver
> * Do `ls -l | grep lock`, give us the output
No visual output. Returned me to bash.
> * Do `groups`, give us the output
evan adm dialout fax cdrom floppy tape sudo audio dip video plugdev fuse
lpadmin netdev admin nopasswdlogin sambashare scanner powerdev vboxusers
dialup chrome-remote-desktop
> * Do `ls -l /dev/tty*`, give us the output
Long one:
crw-rw-rw- 1 root tty     5,  0 May 24 15:44 /dev/tty
crw--w---- 1 root tty     4,  0 May 24 15:32 /dev/tty0
crw-rw---- 1 root tty     4,  1 May 24 15:32 /dev/tty1
crw--w---- 1 root tty     4, 10 May 24 15:32 /dev/tty10
crw--w---- 1 root tty     4, 11 May 24 15:32 /dev/tty11
crw--w---- 1 root tty     4, 12 May 24 15:32 /dev/tty12
crw--w---- 1 root tty     4, 13 May 24 15:32 /dev/tty13
crw--w---- 1 root tty     4, 14 May 24 15:32 /dev/tty14
crw--w---- 1 root tty     4, 15 May 24 15:32 /dev/tty15
crw--w---- 1 root tty     4, 16 May 24 15:32 /dev/tty16
crw--w---- 1 root tty     4, 17 May 24 15:32 /dev/tty17
crw--w---- 1 root tty     4, 18 May 24 15:32 /dev/tty18
crw--w---- 1 root tty     4, 19 May 24 15:32 /dev/tty19
crw-rw---- 1 root tty     4,  2 May 24 15:32 /dev/tty2
crw--w---- 1 root tty     4, 20 May 24 15:32 /dev/tty20
crw--w---- 1 root tty     4, 21 May 24 15:32 /dev/tty21
crw--w---- 1 root tty     4, 22 May 24 15:32 /dev/tty22
crw--w---- 1 root tty     4, 23 May 24 15:32 /dev/tty23
crw--w---- 1 root tty     4, 24 May 24 15:32 /dev/tty24
crw--w---- 1 root tty     4, 25 May 24 15:32 /dev/tty25
crw--w---- 1 root tty     4, 26 May 24 15:32 /dev/tty26
crw--w---- 1 root tty     4, 27 May 24 15:32 /dev/tty27
crw--w---- 1 root tty     4, 28 May 24 15:32 /dev/tty28
crw--w---- 1 root tty     4, 29 May 24 15:32 /dev/tty29
crw-rw---- 1 root tty     4,  3 May 24 15:32 /dev/tty3
crw--w---- 1 root tty     4, 30 May 24 15:32 /dev/tty30
crw--w---- 1 root tty     4, 31 May 24 15:32 /dev/tty31
crw--w---- 1 root tty     4, 32 May 24 15:32 /dev/tty32
crw--w---- 1 root tty     4, 33 May 24 15:32 /dev/tty33
crw--w---- 1 root tty     4, 34 May 24 15:32 /dev/tty34
crw--w---- 1 root tty     4, 35 May 24 15:32 /dev/tty35
crw--w---- 1 root tty     4, 36 May 24 15:32 /dev/tty36
crw--w---- 1 root tty     4, 37 May 24 15:32 /dev/tty37
crw--w---- 1 root tty     4, 38 May 24 15:32 /dev/tty38
crw--w---- 1 root tty     4, 39 May 24 15:32 /dev/tty39
crw-rw---- 1 root tty     4,  4 May 24 15:32 /dev/tty4
crw--w---- 1 root tty     4, 40 May 24 15:32 /dev/tty40
crw--w---- 1 root tty     4, 41 May 24 15:32 /dev/tty41
crw--w---- 1 root tty     4, 42 May 24 15:32 /dev/tty42
crw--w---- 1 root tty     4, 43 May 24 15:32 /dev/tty43
crw--w---- 1 root tty     4, 44 May 24 15:32 /dev/tty44
crw--w---- 1 root tty     4, 45 May 24 15:32 /dev/tty45
crw--w---- 1 root tty     4, 46 May 24 15:32 /dev/tty46
crw--w---- 1 root tty     4, 47 May 24 15:32 /dev/tty47
crw--w---- 1 root tty     4, 48 May 24 15:32 /dev/tty48
crw--w---- 1 root tty     4, 49 May 24 15:32 /dev/tty49
crw-rw---- 1 root tty     4,  5 May 24 15:32 /dev/tty5
crw--w---- 1 root tty     4, 50 May 24 15:32 /dev/tty50
crw--w---- 1 root tty     4, 51 May 24 15:32 /dev/tty51
crw--w---- 1 root tty     4, 52 May 24 15:32 /dev/tty52
crw--w---- 1 root tty     4, 53 May 24 15:32 /dev/tty53
crw--w---- 1 root tty     4, 54 May 24 15:32 /dev/tty54
crw--w---- 1 root tty     4, 55 May 24 15:32 /dev/tty55
crw--w---- 1 root tty     4, 56 May 24 15:32 /dev/tty56
crw--w---- 1 root tty     4, 57 May 24 15:32 /dev/tty57
crw--w---- 1 root tty     4, 58 May 24 15:32 /dev/tty58
crw--w---- 1 root tty     4, 59 May 24 15:32 /dev/tty59
crw-rw---- 1 root tty     4,  6 May 24 15:32 /dev/tty6
crw--w---- 1 root tty     4, 60 May 24 15:32 /dev/tty60
crw--w---- 1 root tty     4, 61 May 24 15:32 /dev/tty61
crw--w---- 1 root tty     4, 62 May 24 15:32 /dev/tty62
crw--w---- 1 root tty     4, 63 May 24 15:32 /dev/tty63
crw--w---- 1 root tty     4,  7 May 24 15:32 /dev/tty7
crw--w---- 1 root tty     4,  8 May 24 15:32 /dev/tty8
crw--w---- 1 root tty     4,  9 May 24 15:32 /dev/tty9
crw------- 1 root root    5,  3 May 24 15:32 /dev/ttyprintk
crw-rw---- 1 root dialout 4, 64 May 24 15:32 /dev/ttyS0
crw-rw---- 1 root dialout 4, 65 May 24 15:32 /dev/ttyS1
crw-rw---- 1 root dialout 4, 74 May 24 15:32 /dev/ttyS10
crw-rw---- 1 root dialout 4, 75 May 24 15:32 /dev/ttyS11
crw-rw---- 1 root dialout 4, 76 May 24 15:32 /dev/ttyS12
crw-rw---- 1 root dialout 4, 77 May 24 15:32 /dev/ttyS13
crw-rw---- 1 root dialout 4, 78 May 24 15:32 /dev/ttyS14
crw-rw---- 1 root dialout 4, 79 May 24 15:32 /dev/ttyS15
crw-rw---- 1 root dialout 4, 80 May 24 15:32 /dev/ttyS16
crw-rw---- 1 root dialout 4, 81 May 24 15:32 /dev/ttyS17
crw-rw---- 1 root dialout 4, 82 May 24 15:32 /dev/ttyS18
crw-rw---- 1 root dialout 4, 83 May 24 15:32 /dev/ttyS19
crw-rw---- 1 root dialout 4, 66 May 24 15:32 /dev/ttyS2
crw-rw---- 1 root dialout 4, 84 May 24 15:32 /dev/ttyS20
crw-rw---- 1 root dialout 4, 85 May 24 15:32 /dev/ttyS21
crw-rw---- 1 root dialout 4, 86 May 24 15:32 /dev/ttyS22
crw-rw---- 1 root dialout 4, 87 May 24 15:32 /dev/ttyS23
crw-rw---- 1 root dialout 4, 88 May 24 15:32 /dev/ttyS24
crw-rw---- 1 root dialout 4, 89 May 24 15:32 /dev/ttyS25
crw-rw---- 1 root dialout 4, 90 May 24 15:32 /dev/ttyS26
crw-rw---- 1 root dialout 4, 91 May 24 15:32 /dev/ttyS27
crw-rw---- 1 root dialout 4, 92 May 24 15:32 /dev/ttyS28
crw-rw---- 1 root dialout 4, 93 May 24 15:32 /dev/ttyS29
crw-rw---- 1 root dialout 4, 67 May 24 15:32 /dev/ttyS3
crw-rw---- 1 root dialout 4, 94 May 24 15:32 /dev/ttyS30
crw-rw---- 1 root dialout 4, 95 May 24 15:32 /dev/ttyS31
crw-rw---- 1 root dialout 4, 68 May 24 15:32 /dev/ttyS4
crw-rw---- 1 root dialout 4, 69 May 24 15:32 /dev/ttyS5
crw-rw---- 1 root dialout 4, 70 May 24 15:32 /dev/ttyS6
crw-rw---- 1 root dialout 4, 71 May 24 15:32 /dev/ttyS7
crw-rw---- 1 root dialout 4, 72 May 24 15:32 /dev/ttyS8
crw-rw---- 1 root dialout 4, 73 May 24 15:32 /dev/ttyS9
