[vcf-midatlantic] ADTPro help
J. Alexander Jacocks
jjacocks at gmail.com
Tue May 24 15:57:07 EDT 2016
Evan,
You have said that you have a fully 32bit version of Linux installed. If
this is the case, you do not have the support libraries necessary for a
64bit application (the rxtx library version listed in your output is
x86_64, or 64bit). This is probably what is causing the issue.
I'm guessing that the adtpro.sh script is somehow trying to launch 64bit
Java, though I haven't had a chance to look at the script, itself. That
will never work on a 32bit Linux install.
- Alex
On Tue, May 24, 2016 at 3:47 PM, Evan Koblentz via vcf-midatlantic <
> * Run it in the console, give us the complete output
> Ran it as sudo. Got this:
> Java HotSpot(TM) Server VM warning: You have loaded library
> /home/evan/ADTPro-2.0.1/lib/rxtx/rxtx-2.2pre2-local/x86_64-unknown-linux-gnu/librxtxSerial.so
> which might have disabled stack guard. The VM will try to fix the stack
> guard now.
> It's highly recommended that you fix the library with 'execstack -c
> <libfile>', or link it with '-z noexecstack'.
> java.lang.UnsatisfiedLinkError:
> /home/evan/ADTPro-2.0.1/lib/rxtx/rxtx-2.2pre2-local/x86_64-unknown-linux-gnu/librxtxSerial.so:
> wrong ELF class: ELFCLASS64 (Possible cause: architecture word width
> mismatch) thrown while loading gnu.io.RXTXCommDriver
> * Do `ls -l | grep lock`, give us the output
> No visual output. Returned me to bash.
> * Do `groups`, give us the output
> evan adm dialout fax cdrom floppy tape sudo audio dip video plugdev fuse
> lpadmin netdev admin nopasswdlogin sambashare scanner powerdev vboxusers
> dialup chrome-remote-desktop
> * Do `ls -l /dev/tty*`, give us the output
> Long one:
> crw-rw-rw- 1 root tty 5, 0 May 24 15:44 /dev/tty
> crw--w---- 1 root tty 4, 0 May 24 15:32 /dev/tty0
> crw-rw---- 1 root tty 4, 1 May 24 15:32 /dev/tty1
> crw--w---- 1 root tty 4, 10 May 24 15:32 /dev/tty10
> crw--w---- 1 root tty 4, 11 May 24 15:32 /dev/tty11
> crw--w---- 1 root tty 4, 12 May 24 15:32 /dev/tty12
> crw--w---- 1 root tty 4, 13 May 24 15:32 /dev/tty13
> crw--w---- 1 root tty 4, 14 May 24 15:32 /dev/tty14
> crw--w---- 1 root tty 4, 15 May 24 15:32 /dev/tty15
> crw--w---- 1 root tty 4, 16 May 24 15:32 /dev/tty16
> crw--w---- 1 root tty 4, 17 May 24 15:32 /dev/tty17
> crw--w---- 1 root tty 4, 18 May 24 15:32 /dev/tty18
> crw--w---- 1 root tty 4, 19 May 24 15:32 /dev/tty19
> crw-rw---- 1 root tty 4, 2 May 24 15:32 /dev/tty2
> crw--w---- 1 root tty 4, 20 May 24 15:32 /dev/tty20
> crw--w---- 1 root tty 4, 21 May 24 15:32 /dev/tty21
> crw--w---- 1 root tty 4, 22 May 24 15:32 /dev/tty22
> crw--w---- 1 root tty 4, 23 May 24 15:32 /dev/tty23
> crw--w---- 1 root tty 4, 24 May 24 15:32 /dev/tty24
> crw--w---- 1 root tty 4, 25 May 24 15:32 /dev/tty25
> crw--w---- 1 root tty 4, 26 May 24 15:32 /dev/tty26
> crw--w---- 1 root tty 4, 27 May 24 15:32 /dev/tty27
> crw--w---- 1 root tty 4, 28 May 24 15:32 /dev/tty28
> crw--w---- 1 root tty 4, 29 May 24 15:32 /dev/tty29
> crw-rw---- 1 root tty 4, 3 May 24 15:32 /dev/tty3
> crw--w---- 1 root tty 4, 30 May 24 15:32 /dev/tty30
> crw--w---- 1 root tty 4, 31 May 24 15:32 /dev/tty31
> crw--w---- 1 root tty 4, 32 May 24 15:32 /dev/tty32
> crw--w---- 1 root tty 4, 33 May 24 15:32 /dev/tty33
> crw--w---- 1 root tty 4, 34 May 24 15:32 /dev/tty34
> crw--w---- 1 root tty 4, 35 May 24 15:32 /dev/tty35
> crw--w---- 1 root tty 4, 36 May 24 15:32 /dev/tty36
> crw--w---- 1 root tty 4, 37 May 24 15:32 /dev/tty37
> crw--w---- 1 root tty 4, 38 May 24 15:32 /dev/tty38
> crw--w---- 1 root tty 4, 39 May 24 15:32 /dev/tty39
> crw-rw---- 1 root tty 4, 4 May 24 15:32 /dev/tty4
> crw--w---- 1 root tty 4, 40 May 24 15:32 /dev/tty40
> crw--w---- 1 root tty 4, 41 May 24 15:32 /dev/tty41
> crw--w---- 1 root tty 4, 42 May 24 15:32 /dev/tty42
> crw--w---- 1 root tty 4, 43 May 24 15:32 /dev/tty43
> crw--w---- 1 root tty 4, 44 May 24 15:32 /dev/tty44
> crw--w---- 1 root tty 4, 45 May 24 15:32 /dev/tty45
> crw--w---- 1 root tty 4, 46 May 24 15:32 /dev/tty46
> crw--w---- 1 root tty 4, 47 May 24 15:32 /dev/tty47
> crw--w---- 1 root tty 4, 48 May 24 15:32 /dev/tty48
> crw--w---- 1 root tty 4, 49 May 24 15:32 /dev/tty49
> crw-rw---- 1 root tty 4, 5 May 24 15:32 /dev/tty5
> crw--w---- 1 root tty 4, 50 May 24 15:32 /dev/tty50
> crw--w---- 1 root tty 4, 51 May 24 15:32 /dev/tty51
> crw--w---- 1 root tty 4, 52 May 24 15:32 /dev/tty52
> crw--w---- 1 root tty 4, 53 May 24 15:32 /dev/tty53
> crw--w---- 1 root tty 4, 54 May 24 15:32 /dev/tty54
> crw--w---- 1 root tty 4, 55 May 24 15:32 /dev/tty55
> crw--w---- 1 root tty 4, 56 May 24 15:32 /dev/tty56
> crw--w---- 1 root tty 4, 57 May 24 15:32 /dev/tty57
> crw--w---- 1 root tty 4, 58 May 24 15:32 /dev/tty58
> crw--w---- 1 root tty 4, 59 May 24 15:32 /dev/tty59
> crw-rw---- 1 root tty 4, 6 May 24 15:32 /dev/tty6
> crw--w---- 1 root tty 4, 60 May 24 15:32 /dev/tty60
> crw--w---- 1 root tty 4, 61 May 24 15:32 /dev/tty61
> crw--w---- 1 root tty 4, 62 May 24 15:32 /dev/tty62
> crw--w---- 1 root tty 4, 63 May 24 15:32 /dev/tty63
> crw--w---- 1 root tty 4, 7 May 24 15:32 /dev/tty7
> crw--w---- 1 root tty 4, 8 May 24 15:32 /dev/tty8
> crw--w---- 1 root tty 4, 9 May 24 15:32 /dev/tty9
> crw------- 1 root root 5, 3 May 24 15:32 /dev/ttyprintk
> crw-rw---- 1 root dialout 4, 64 May 24 15:32 /dev/ttyS0
> crw-rw---- 1 root dialout 4, 65 May 24 15:32 /dev/ttyS1
> crw-rw---- 1 root dialout 4, 74 May 24 15:32 /dev/ttyS10
> crw-rw---- 1 root dialout 4, 75 May 24 15:32 /dev/ttyS11
> crw-rw---- 1 root dialout 4, 76 May 24 15:32 /dev/ttyS12
> crw-rw---- 1 root dialout 4, 77 May 24 15:32 /dev/ttyS13
> crw-rw---- 1 root dialout 4, 78 May 24 15:32 /dev/ttyS14
> crw-rw---- 1 root dialout 4, 79 May 24 15:32 /dev/ttyS15
> crw-rw---- 1 root dialout 4, 80 May 24 15:32 /dev/ttyS16
> crw-rw---- 1 root dialout 4, 81 May 24 15:32 /dev/ttyS17
> crw-rw---- 1 root dialout 4, 82 May 24 15:32 /dev/ttyS18
> crw-rw---- 1 root dialout 4, 83 May 24 15:32 /dev/ttyS19
> crw-rw---- 1 root dialout 4, 66 May 24 15:32 /dev/ttyS2
> crw-rw---- 1 root dialout 4, 84 May 24 15:32 /dev/ttyS20
> crw-rw---- 1 root dialout 4, 85 May 24 15:32 /dev/ttyS21
> crw-rw---- 1 root dialout 4, 86 May 24 15:32 /dev/ttyS22
> crw-rw---- 1 root dialout 4, 87 May 24 15:32 /dev/ttyS23
> crw-rw---- 1 root dialout 4, 88 May 24 15:32 /dev/ttyS24
> crw-rw---- 1 root dialout 4, 89 May 24 15:32 /dev/ttyS25
> crw-rw---- 1 root dialout 4, 90 May 24 15:32 /dev/ttyS26
> crw-rw---- 1 root dialout 4, 91 May 24 15:32 /dev/ttyS27
> crw-rw---- 1 root dialout 4, 92 May 24 15:32 /dev/ttyS28
> crw-rw---- 1 root dialout 4, 93 May 24 15:32 /dev/ttyS29
> crw-rw---- 1 root dialout 4, 67 May 24 15:32 /dev/ttyS3
> crw-rw---- 1 root dialout 4, 94 May 24 15:32 /dev/ttyS30
> crw-rw---- 1 root dialout 4, 95 May 24 15:32 /dev/ttyS31
> crw-rw---- 1 root dialout 4, 68 May 24 15:32 /dev/ttyS4
> crw-rw---- 1 root dialout 4, 69 May 24 15:32 /dev/ttyS5
> crw-rw---- 1 root dialout 4, 70 May 24 15:32 /dev/ttyS6
> crw-rw---- 1 root dialout 4, 71 May 24 15:32 /dev/ttyS7
> crw-rw---- 1 root dialout 4, 72 May 24 15:32 /dev/ttyS8
> crw-rw---- 1 root dialout 4, 73 May 24 15:32 /dev/ttyS9
