[vcf-midatlantic] ADTPro help
Systems Glitch
systems.glitch at gmail.com
Tue May 24 15:59:33 EDT 2016
> wrong ELF class: ELFCLASS64 (Possible cause: architecture word width
> mismatch) thrown while loading gnu.io.RXTXCommDriver
The adtpro.sh script has screwed up and is trying to use a 64-bit library. Who knows why. "Java: Write Once, Debug Everywhere" (not that this is technically a problem with *Java*). Open up adtpro.sh in a text editor, look for a line like
OS_ARCH=`uname -p`
And change it to:
OS_ARCH="i686"
> > * Do `ls -l | grep lock`, give us the output
> No visual output. Returned me to bash.
Probably irrelevant at this point, but I screwed up, I meant:
`ls -l /var | grep lock`
> > * Do `ls -l /dev/tty*`, give us the output
> Long one:
- snip -
I don't see a USB adapter in there, was it plugged in when you did the `ls`?
Thanks,
Jonathan
